hi all
I was trying to diagnose an ignition issue where I only get 3 volts at the coil tonight and I took a live from the slave sol and put it to the resistance wire on the choke that feeds the coil. Click headed then no volts at coil and no click from solenoid when ignition it switched to run.
I also noted that both wires on the front of the solenoid had continuity to the coil.
Any help greatfully received as hair is starting to fall out here.
Cheers
Ron
Cheers
Ron
