40 hp 4cyl cold start problem
bob and nancy
fires on two cyl,cold excess oil in the carb ? drained the carbs annd looked like excess oil in the gas. started fine after that so suspect oil draining into the carbs. would it be better to disconnect oil injection and mix my own and how to do. does the pump need oil to lube oe just disconnect. checked the fuel selonoid and works good but suspect the excess oil slows the fuel flow to crankcase thanks forum. bob
