Adjust throttle/gear handle
dogrocco
I just bought a boat (Angler 2004 with a 2003 Evinrude 200HP). The gear lever has some play on it and sometimes I have trouble starting it due to not been properly in neutral.
How can I adjust the lever? I want to make sure that it is properly in neutral and that it engage in drive properly. Your help is greatly appreciated.
Anchor Management 1
Re: Adjust throttle/gear handle
I think on that one you put the handle all the way foward and there is a hole at the bottom. Inside hole is a allan head bolt to tighten.
boobie
You may have some probs in the control box or else the the cables are out of adjustment on the mtr. Or else you have a loose or bad neutral safety switch in the box.
duckland23
Just my two cents . But ist placed togetter the right way?. My Tiller handle on my smaller motor had a tight handle and it should turn lose . If you parts are placed in the wrong place it will not work right . I just thought I would ask you . You can also look on marineengine.com at things like this . I had the same problem starting my motor the way your telling the people on here . Its some looking around to see whats causeing the problem first . You may need some grease in something or need to adjust something as well . But I bet if you take a good look you can find out whats wrong . I dont think its that hard .
