1978 Johnson Javelin 85 HP V4
A few weeks back my throttle cable snapped while on the lake. I was able to limp back to the boat launch and get home. I replaced the cable. It idles great, shifts very smooth, but I can no longer get to WOT. I push the lever forward and it seems to stop 2" short of where it did before. How do I adjust the length of travel for the cable without screwing with my idle speed?
This is the cable I replaced, which basically uses set screws on both ends to attach to the motor and control lever.
http://www.iboats.com/OMC-Cont-Cabl...5038219--session_id.767428253--view_id.169404
Edit: Sorry but my original Msg had everything backwards. I actually had to replace the shifter cable. I set it where the motor will shift perfect moving into forward and reverse, but now i have less travel in my throttle.
