mitchamus09
- May 7, 2012
- 2
OK I just received a 1985 Johnson 9.9 J10ELCOM motor.
Ran the motor last sunday no issues. fast forward to this sunday motor started fine used for a while changing spots
i dropped the handle and the motor stalled out and would not start. Thought maybe it flooded so waited a while.
still nothing. Figured out a way to start was pull the choke in and out while cranking once it starts put it in gear and punch it seems to only stay running from half to full throttle any lower it stalls.
The first time i ran the oil/gas mix was 100:1 as indicated on the motor. the second time oil/gas mix was 50:1 as indicated by the marine repair shop, they said the motor was made with that sticker but take it off and run 50:1.
It has new NGK plugs, new fuel line.
Any help would be appreciated.
I did not turn slow speed adjustment nob not sure exactly what that does.
Could it be a clogged jet?
