OMC King Cobra dies upon going from idle to fulll speed
kc157
My OMC King Cobra 1998 5.7 litre engine was running just fine on a recent outing. I stopped at a Marina on the water and filled up with gas. Upon exiting the marina the engine ran fine at idle but upon acceleration to 25000 rpm the boat coughs and dies. I can idle for hours but cannot get much above 1500 rpm before the engine dies. Could it be coincidental and have bad gas? Bad fuel filter? Bad inline filter? Carb float problems? Where do I start?
kmarine
Re: OMC King Cobra dies upon going from idle to fulll speed
Did you check to see if your esa is working properly? you may have a possible shift linkage issue. common cobra drive issue although I am not absolutely sure if this applys to the king cobra also.
kmarine
try replacing fuel filter to sii if you bought water insted of gas?
HT32BSX115
It probably doesn't have an ESA if it's a 98. Only the Dog-clutch Cobras had the ESA. By 1998, All the "Cobras" were SX's (and Volvo cone clutch models)
It'll help a lot if you post your year model AND model number.
HCMQA
My 87' 4.3 cobra does the same thing and it is not the esa.
Changed all my filters and so far so good.
Did they make King Cobras for 5.7's?
HT32BSX115
They called a LOT of different models "King" Cobra. It really doesn't mean a lot.
In 1987, The only model called "king" was the one behind the 460. It was quite a bit bigger than the other models for obvious reasons.
For the OP, the problem could be any of the reasons you mentioned...........
But when you have problems right after refueling, it's usually related to the refueling.
Yes.
