12ft valco restoration
brunette63
I just bought a 12ft valco model a-12 aluminum boat, rivited, outside hull has no dents but could be polished. Inside isnt bad i pulled the benches up to put some new boards down. as far as painting goes does anyone know what i should use for the inside of the boat and what to use to polish the ouside? thanks and help is needed its my first boat
Bob_VT
Re: 12ft valco restoration
Welcome to iboats.
Just start reading the restoration section. There questions have been answered thousands of times. Your best first step is research ;)
Woodonglass
At the bottom of your thread now, are 5 similar threads that will be a good place for you to start your research. Ext. Grade Plywood (Arauco) is a good Seat choice coated with 4-5 coats of Spar Varnish.
