Engine stalling out after being in gear. 1999 5.0 Merc
dcody978
Hello everyone it has been a while since I have posted and any help with this problem would be great! I have a 1999 5.0 Mercruiser EFI. Runs and idles great the issue is that after being put into gear and then back to neutral the engine stalls out after a second or two. When in reverse and then put back into neutral the engine continues to run as it should. Only stalls out after being in forward. Brand new spark plugs, very clean manifolds and brand new starter solenoid. Any help would be great thanks.
Pete104
Re: Engine stalling out after being in gear. 1999 5.0 Merc
Shift cable
Don S
What drive do you have? Alpha or Bravo
Pete104
Yea, that would make a difference
