i have a 200 ficht 115 that misses at low rpm and takes forever to get the boat on plane. once the motor is running above 3500 rpm it takes off and runs fine. repaced both fuel pumps,plugs,fuel filter,ignition switch,and primer bulb. motor seems to run better sometimes but slides back into its cruddy mode when it wants to. please help. compression checked out ok .
