Hello All
New guy on the forum I am looking for some help with a motor I am tuning up for my daughters boat.
1965 5hp Johnson LD10s.Motor ran for me in a barrel,but I want to minimize the headaches. I am in the process of replacing the water pump impeller and found some missing parts.The parts that appear to be gone are 1 thru 7 on the parts page. I am using the 1968 Ld-13b online diagram for reference. I have the correct part numbers and the parts are available, But why were they removed? Clymer manual only mentions an o'ring. This assembly or seals and spring appears to protect the upper splines from getting wet? is it common to remove them?
Thank you
Scott
Thank you
Scott
