I have a 2009 Mercruiser 3.0L TKS 135 hp and it has a problem once warmed up. The choke stays closed unless I hit the throttle hard. As a result the engine often stalls due to too much gas when trying to run at slow speeds. If I give it gas at slow speeds it will flood and stall. When I try faster speeds I have no problem. I took a look at carb to see what happens. The choke only opens up at around 3/4 rpm. Is there something I can do? Is there an adjustment for this.
