2006 250 HPDI. There is a schrader valve on the top of the VST mine is leaking quit a bit. There is no part number for this in the yamaha parts book or I would just buy one. I removed it to work on it and that was a big mistake. It is a pressed in fit. Strange thing is that it has a rubber O ring in a groove on the end of it. You would think it was serviceable. Any way if I can find new guts for it that will work what would I seal this with. The O ring is there to hold the gas pressure 30 lbs at the vst I think. The valve is brass pressed into Aluminum. I am concerned that in removing it I will have loosened the pressed fit. I am sure I can tap it back in but will it hold 30 PSI. I don't want a trial and error here because it will get worse every time I try something. Any one ran into this?
