Re: Help on installing Gasket
First of all, I just did the same job on an 85 Eska 5hp, and it's a lot less daunting once you get into it. I actually have two of these (twins) and I'll be replacing the gasket on the other today...
That being said, it sounds like you have the manual. The way I've always looked at it,
personally, is there is no reason not to follow the manuals exact specifications. Just to give you a different perspective, here are the bullet points of things to have handy and watch out for...
A.) I started with a clean, dry cylinder, and a clean, dry motor/cowl in general. This was so if by chance anything were to get into the cylinder, it wouldn't "adhere" to any oil or other liquid, and would be easy to blow out with compressed air. ALWAYS have compressed air around. I put the piston at top dead center and constantly blew any debris away throughout the job. I also like the plastic bag idea mentioned above, but have yet to try it...
B.) The metal that the gasket lays on is very soft, and very fragile. I don't like liquid remover because, though effective, it's wickedly "hot" and can be messy. I used a razor blade (which most will say is a horrible idea, but is very effective when used with care) and a magnifying glass to remove the "chunks", and then some 6000 grit wet/dry paper with a little "Mom's 409" (that's spit) to get the left behind, and a touch of Sea Foam "Deep Creep" to finish off the hard stuff/carbon. The end result was nearly flawless, with no scratching or pitting caused by the removal. The bottom line is work SLOWLY and CAREFULLY, and you'll be just fine.
C.) After that I replaced the gasket using a SMALL amount of BRP Sealer (peanut butter). I bought new screws to replace the old ones. Grade 8 - 1/4-20's on mine. Then I torqued them all evenly to the manufacturer recommended 90 in. lbs. (check your manual, mine was 80-100 in. lbs recommended, but other similar Eska motors vary)
D.) Though I'm sure it might still run, don't use gasket maker exclusively (or at all in my opinion, unless it's already horribly scored), and don't try to tighten bare metal to bare metal to seal the head. That's like using a band-aid to replace a chain link...
The end result was great, as there is usually no better way to go than by the book. Also, check around the forum for other similar jobs. Helped me a ton.
P.S. - Listen to mrcrabs...he's schooled me a few times and has never steered me in the wrong direction.
