1974 mercury 85hp controls when i split the the case on the control boxa pin came out
arthur1988
ok well when i took it apart a little pin size metal piece came out and dont know where it came from does any one have a diagram ??
carholme
Re: 1974 mercury 85hp controls when i split the the case on the control boxa pin came
If you look in the upper forward corners of the case halves, you will see a thin piece of spring steel with a slot formed in it for the little pin to fit into.
Here is a poor picture of the box:
http://www.crowleymarine.com/mercury-outboard/parts/640_28.cfm
Item 2 is the thin piece of metal with the slot and item 3 is the pin you have. You slide the pin and the thin pice together into the slot and ensure they stay there while you push to two halves together on their alignment pins.
Clear as mud?
Gerry
