I have a 3 port Pollak fuel valve in my boat. Lots of wires were diconected behind the dash and my toggle switch for
my tank changeover was disconected. My valve has only two wires. The one is a good ground that I have already checked
and the other black wire goes to the dash. I tested the valve by applying Pos. from the battery and it looks like it works.
I found a wire behind the dash that has Pos. when the key is turned on but I'm scared to connect it and in return ground
something else. Any Thoughts?
