Help I'm losing sleep. I have read every post about cooling in iboats in the last 3 years and I'm not finding anwers. <br /><br />The boat is running cool, never warming up past the 125 degree mark. What I have done- tested the thermostat (160)and it is working but I replaced it anyway. Put in a new impeller a week ago, after an overheat. I believe the temp gauge is working reasonalbly accurate because it was up to 190-200 or so when the overheat alarm went off. After a run I can put my hand on everything -thermostat housing, block etc and it feels only warm. <br /> <br />I have the thermostat installed correctly, I doubled checked that. <br /><br />Any suggestions? <br /><br />4.3 VP 2001 with sx drive<br /><br />P.S. Can someone also explain how the cooling system flows... from impeller to where it exits the drive.
