So I am doing some much needed work on my boat. I was wondering if anyone out there has any experience on this motor out there? I went to the library and looked through the Clymers and Seloc Manuals but did not have the answers to my questions below.
First off this motor caught fire back at the end of 2010. It has been sitting since because of the lack of time and money. I am in the process of rebuilding the carb and replacing some wires and other items that were a loss in the fire. This process is almost all done. I also pulled the lower unit to replace the water pump. My questions are on the lower unit on some items. First is a question on the Seat Assembly and the Seal Splined and how they line up on the drive shaft? I need to know the orientation when put on the drive shaft. When the lower unit came out the seat assembly was in pieces and the seal splined was split and fell off as well. Also need to know the orientation of the cam reverse locking. That also came off the shift shaft and not sure which direction to put it in. Any help would be great!
Thanks Phil
Thanks Phil
