Hello All
I have just bought a Mercury 15 Super here in Australia and I understand that it is the Tohatsu 18Hp
My query is that the motor is not getting full throttle, It will leap out of the hole and pull hard but does not seem to have much top speed
I had a look at the timing and carb linkages and while it is getting to the 20 degree timing mark the carb butterfly is only getting to half way
Now it is only a simple adjustment to take the timing to 25 degrees and this will also give me more butterfly opening, But should I do that or just adjust the throttle linkage instead
I am thinking that to derate this motor from an 18 to a 15 this is how they've done it but if there's 3 more ponies available I would like to have them
I have the factory service manual and it shows some 18's as having 25 degree timing but I would like to be sure before doing the adjustment
Link to both engines
http://www.tohatsu.com.au/content/m18e2
http://www.mercurymarine.com.au/home/outboards/twostroke/-15-hp---6-hp/15-hp-super.aspx
Thanks for any advice
