Re: 1999 mercruiser 4.3 cracked head relplace with 2000 S-10 blazer heads
flat tappet and roller cams require different length pushrods. however just changing rockers going from stamped rockers to full rollers may require different length push rods. sometimes a +.100 will be required. you will have to measure them.
my first thought is you have the valves set too tight.
