Recently bought a 70s model 16ft bass tracker. The transom wood isn't rotted, but the transom does flex when I pull up/push down on the motor. I want to reinforce it. Originally I was planning on replacing the transom wood and see what that did, but the way it is installed... the rear is welded and bolted around the wood. There's no way to replace the wood without cutting all the welds, replacing the wood, and re-welding. That will get expensive in a hurry.
So what I'm thinking is to bolt a fairly thick piece of aluminum across the back of the transom. I have about 1/2 inch of space under the motor mount to play with. I may also have a couple more straps welded to the top of the transom. It already has two.
Any ideas?
I'll try and get some pics posted later today.
Any ideas?
