been looking
- Apr 29, 2012
- 5
I have a 1964 Sea Nymph and would like to locate the original aluminum plug with rubber gasket for it.
The hole is 1" across. Hope this helps. ThanksWelcome aboard! Is there a difference in size from newer ones? I have a couple from the 70's
It is also threaded.The hole is 1" across. Hope this helps. Thanks
You could use one of those rubber expansion types, you turn a small T handle and the rubber expands into the opening and seals it.
You guys do know that this site does sell parts , right?
http://www.iboats.com/Boat-Parts-Ac...37--keywords.drain plug--session_id.274891221
