bigjohn767
- Apr 30, 2012
- 2
My brother-in-law has an '85 Evinrude 40hp that runs rough and sometimes won't idle. He has rebuilt the fuel pump and both carbs, replaced all gas lines, and put in new plugs. It idles OK now but sometimes just shuts down. It also has what I call a "miss" in the engine. Being a car guy, I asked about float adjustments and such and he said he didn't know to check the floats. Could the floats be causing the problem? He did clean all the carb parts but I don't think he ran a wire through the jets as suggested in another post. Another clue is the lower plug appears to be wet while the upper plug is dry.
I thank you in advance for any suggestions!
John
John
