Hey guys, got a '90 Bayliner Capri outboard...was letting my wife's cousin take a look at her this past weekend and I took a closer gander underneath the flooring into the bilge or ski locker.whatever you want to call the area under the deck between the seats. Well, under the deck, where it was dark....you can see daylight through the glass. Have someone move their hand over the keel in that area, and you see the shadow moving. My thought is someone hit something or perhaps beached on a rock and tore a hole in the hull. Can't tell there was any repair outside or in, but...there is definitely a thin spot. Is this a thing with bayliners? Thin spots on the glass now and then, or am I thinking along the correct lines? I'm going to reglass the area to reinforce and was thinking of laying some 6" wide bent to contour sections of steel (14 ga or something...no 1/4 to just add stupid weight, but figured grassing in pieces butted together to follow the contour of the hull would help reinforce that area. Am I going overkill there? Just glass it and forget about it? I'm plenty familiar with fiberglass use and technique, as I used to build fiberglass pool systems for ASA. Years ago, granted, but...that whole bicycle thing...anyways, just wanted to get some input as to whether I should just glass and go, and if this is something indicating damage and I should tear up the deck and investigate the whole situation. Any thought would be appreciated. Thanks guys.
