My 50 HP 4 stroke (2001) outboard motor overheat alarm sounds (steady alarm) only when at full throttle. It runs fine at lower speeds. I have replaced the water pump, pump housing and the thermostat. The tell tale water stream is strong and warm. When the alarm sounds the engine loses power. anThe alarm is silenced by shutting off the key. I can restart it immediatly and the alarm goes off and motor runs fine as long as I go 1/2-3/4 throttle.
Any suggestions? Could it possibly be the oil pressure alarm?
Thanks!
Thanks!
