Hello,
I was hoping for some direction in identifying the problems with my motor that started the other day.
My motor is newly rebuilt, and working (at least the first 4 or 5 trips this year), however I had it out the other day and it lost what seems to be it's top gear. I was going along and needed to slow to go around some debris, and when I gave it throttle again it would not go any faster then what I had throttled down to.
I've played with it a little more since then, but haven't been able to indentify the problem. The plugs look good, etc. (surface checks). When I am in neutral the motor seems to operate normally, it's when it goes in gear that the motor doesnt' work right.
I'm thinking this is probably a fairly common problem and I just am not searching for it correctly, but I haven't been able to locate any help information on this problem. Any guidance would be greatly appreciated!
Cheers,
Paul
Cheers,
Paul
