bucket of rivets
- Feb 26, 2012
- 47
At the end of last season I picked up a good running 1983 Mercury 70hp.
The motor ran great, has good compression but was overdue for a water pump.
At that time I tried to remove the lower unit with no luck, it will drop down about 1/8" or so and stop.
Figuring I had all winter to mess with it I went ahead and put the motor on a stand with some weight hanging from the lower unit in hopes that it would drop free, but no luck. I even turned the motor over on its flywheel for a few months with penetrating oil dripped down into the mid section in hopes of freeing the stuck shaft, but again, no luck, it's now been almost 6 months and it's still stuck, it's been sitting with about 50lbs of weight hanging from the lower unit now for two months but it won't budge.
At this point I've finished everything else I wanted to do to the motor, and even ran it on the water for a day in hopes that some torque would help dislodge the driveshaft but again, no luck.
The water pump is still working, but it spits a bit at low RPM, the motor hasn't run hot or anything yet but its no doubt just a matter of time.
The motor has been run mostly only in freshwater, even when in saltwater, it was launched in freshwater up the river a ways. The rest of the motor is super clean.
Any suggestions as to how to free a stuck lower unit or driveshaft?
