Re: 1977 johnson 85hp compression reading good or bad?
The normal reading for compression on this engine when shipped from the factory was around 125 lbs per cyl. You may want to retest the compression with another gauge to verify the numbers. While considered low, it should run with those numbers, but probably won't make the hp it did when new. You could try to do a decarb on the engine and see if the numbers come up any.
