Hey all,
Got a quick question..... so I have changed my t-stat and waterpump assy unit as per service manual. Water "seems" to be flowing fine as far as i can tell via tank test and not hose. Here is my question. When motor is at idle the t-stat housing seems fairly hot. However, when I throttle the motor to 1/2 -to- WOT I can tell water is flowing through the t-stat housing because it feels much cooler. So now my question:
1. Is there not enough pressure to open the t-stat springs to allow flow through an open t-stat until throttle is opened.
- or -
2. Or is the t-stat i have not opening until a fairly hot temp. (hot enough to not be able to keep my palm on the housing for long)
I understand there are diff temp sensitive t-stats, however the one I bought is OEM replacement. I would like for water to flow through the block sooner without the need to run the motor so hard.
thanks for the help
- or -
thanks for the help
