Tohatsu 90A Oil injection removal
Castor
I recently had to replace the fuel hose barbs on my carbs and now they stick out a little more so now the oil tank doesnt fit. I thought I would disconect the injection system. I have unplugged the low oil alarm and plugged the oil intake hose. At 50:1 can I run it this way or do I need to remove the pump entirely? Thank you for any advise.
pvanv
Re: Tohatsu 90A Oil injection removal
You will use more oil than the auto injector system would, but it will work. I would probably eliminate the oil line connection at the intake side of the fuel pump.
