Re: 2005G3 w/ 02 174 Vmax
The boat is a 25 foot tritoon made by G3. Average load would be the boat with a cooler, towels, & 8 passengers. G3 is a Yamaha company so I'd think they would know how to prop it. The tach seemed to read high with boat less than wide open, the tach wwould jump up to 7K rpm. Also, when running across the water, at approx 6,000 RPM, I observed the tach "jumping" with no change in engine RPm. It even jumped up and pegged high a time or two. The one thing I do know it was not cavitation.
Thanks for info on pitot- was able to find it and discover tube had small split causing speed to work but not accurately.
I have owned multiple out bds (both OMC & Merc) but this is my first Yamaha. I have never owned a tritoon either. Not sure if its the difference in boat or motor but this thing is like a rocket from dead stop! I cannot believe how quick it raps-out. This is why the tach is important to make sure we stay within operating specs. It could be that we had such a small load yesterday (3 people, no cooler or supplies) was why it seemed to be too easy to over range the RPM's. I've owned ski boats, 2 pontoons, and 2 deck boats. This tritoon feels different than any of the others. Really expected it to feel same as a pontoon only faster. I failed to mention it has 3" lifting stakes also.
My idle is at least 1300 RPM so i will need to figure out how to adjust that. Motor is 02 but very low hours (<100, original owner estimated in the 50 yr range).
Thanks for all the advice/replies!
