bowler
- Nov 9, 2009
- 277
Hi all,
Second time out in the new toy (2001 Super air nautique, PCM 5.8 GTO, Walter v-drive). Felt a vibration when accelerating (4 on board, no skier) iimediatley after exiting the no wake zone and only at high revs. Took it back to the dock and sometime later when I tried to start the boat the 'ignition beep' would not stop. I pulled the hatches on the vdrive and seemed to hear an intermitent 'clatter' or knocking from the vdrive. Panic time!
Went to start the boat to put it on the trailer and the battery was flat. Swapped it with the spare and beeping stopped but not straight away.
All guages were good and no check engine light. Vdrive light went out after 1200rpm (as it should) on a small 'test drive' after replacing the battery. My instant reaction was 'oh s*** - new gearbox $$$$$$$????????' but after reading a bit online when i got home I seem to see the damper plate popping up as a potential cause for tranny knocking. I checked the prop in the drive way and it seems to have had a bend on one of the blades but I'm not sure what I hit but if I did it was def at low speed, maybe round the slip somewhere - had no feeling of hitting anything at all before accelerating and feeling the vibration for the first time. In total the boat was driven for less than a few minutes.
Anyways, she's going in on monday for a new impeller and shaft seal/packing so i guess I'll now then when the boat tech gets a look.
I'll try and summarise with a couple of questions:
Could hitting the prop at slow speed cause these issues or total a v-drive?
Anyone round here had similar problems, or encountered the worst case scenario, and had to replave a v-drive?
Excuse my rambling but this is my first 'bad day on the water' in 4 years and I'm panicing a bit. Not looking forward to two days of not knowing...
Words of wisdom anyone?
D.
D.
