Island_oki2000
- Aug 31, 2009
- 79
Been working on my kicker, replacing impeller, and trouble shooting why it wont spit water. Got another question. I took the lower unit off and was blowing through the passages from the top of the motor down through the mid section pipe that connects to the lower unit pump housing. When I plugged the hole at the bottom and blew threw the top water passage, air was escaping. I assumed I would not be able to blow through the passage. When I took my finger off I could feel the air coming out the pipe too. So the question is, should that be air tight when I plug the bottom pipe with my finger? If so, what can I do to see what the problem is? DO I have to drop the entire mid section for that?
