I bought an 83 Chris Craft 230 Scorpian w/260 merc (sn#6261027), out drive has a crack by the prop, from what I have read it was probably caused by corosion between the lock ring/bearing retainer and the case
I have preasure tested it and it held 30 psi for two days, as far as I can tell the drive is good except for the crack.
I was thinking about drilling the lock ring and using as pressure washer to remove as much crap as possible from inbetween the retainer and case, installing a new lock ring and welding up the crack, what do you folks think ?
http://home.comcast.net/~a6n6d6y/andy/outdrive1.jpg
http://home.comcast.net/~a6n6d6y/andy/outdrive2.jpg
thanks for looking
andy
thanks for looking
andy
