I have a 1978 Evinrude 70 hp 70873C Outboard Motor. Part way down on the transom is a set screw. What is it for and what if I turned it? New to boating and at first thought it was the drain for lower unit oil. Started turning it out and then realized that it wasn't the drain and so I turned it back in to where I believe it was.
Any input is much appreciated.
Thank you:facepalm:
Thank you:facepalm:
