When I winterized my boat I was unable to turn over motor. Coil wire. It never started and I was freezing so I said screw it. Poured antifreeze in all the water tubes used starter to move water threw... So today I opened
Boat and checked oil, was really high. I drained it and it's not water... It's thin and silver? Not milky like water.
I'm guessing it's gas in the oil? I drained it using the dip stick pump. I know there is more oil in there. If I add 20-50 wt would that counteract the thinning properties of the gas? What would you do?
