Re: alpha 1 inspection
i got me a mc-1. pre alpha1 if ya wanna call it that.
inspections i do are.
yearly impeller inspection/replacement. i've been replacing mine ea. year for the last 6 or so years. i fig. it's cheap insurance that at least my sea water pump is pumping. i inspect my impeller housing while i'm there too.
i pull my drive so i can lub my coupler splines and inspect them.
i grease up my ujoints.
i pressure test my drive prior to dis assembly and after re assembly. if it leaks. ya gotta find out why.
i pull my prop and inspect for fishing line wrapped around my prop shaft a couple times a year. + grease the prop shaft.
i inspect my gimble brg. while the drive is off. also greasing it and spinning it by hand during while lubing it.
i inspect my drive shaft bellows and shift cable bellows.
i inspect my water hose that goes from the drive to the boat for no kinks or rubber breakdown.
i inspect my gear lub for metal shavings and water intrusion every time i remove the gear lub.
i suppose there's more, but that's best i remember at this point.
