Guys, I'm new to boats, but I'm trying to learn as fast as possible.
A couple weeks ago I bought a 6hp 1979 model 6904E outboard engine from a friend (200 bucks). It was supposedly overhauled recently, and was used on a sailboat (its a longshaft). Taking the cover off, the plugs and other things look very clean, there are definitely some new components in there.
I have used the engine for three 2-hour trips on the water. It has been running great. Starts on third pull, moves my 250lb body to 14 mph (by GPS). Today was the third trip, and the trouble started near the end of my trip.
The problem: After 1.5 hours of mostly full-throttle cruising, I noticed the boat seeming to go slower. I thought I might have been imagining things. Then a couple minutes later, the boat just slowed to about walking pace. Fortunately I was almost back to the dock. It eventually quit, though I got it to re-start and idle, but it wouldn't do more than that. Then I got to the dock and I let the engine sit for a few minutes. I then cranked it back up, put it in gear, and gunned the engine. Boom, full power for about 30 seconds, I made a wide circle in the harbor. Then the power went back to crap. So, whatever the problem was, it went away for like 30 seconds, then came back.
I'm running 87 octane gas with 2-stroke oil from Home Depot (the string trimmer stuff).
I got the motor home and put it in the garbage barrel with water, and cleaned off the plugs with carb spray. It would then run at full throttle in the water barrel, but still it didnt sound quite right and didn't rev up very quickly. It would die if I twisted the throttle too quickly.
What is the next thing I should check? I have a compression gauge and I'm a pretty good shade tree mechanic when it comes to cars, have swapped engines, transmissions, everything else virtually. But my knowledge on 2-strokes and boats is not much yet.
Oh yeah, I have been running the engine with the rich/lean control right in the middle.
Thanks for your help.
Adam
Adam
