Re: Please help 1978 25 hp evinrude
I'm at a loss to explain that. Anything over approximately one (1) inch on a 1978 25hp.... nothing would be connected. The water tuibe is out of the water pump, the shift connected is disconnected, obviously all bolts are removed.
The only thing I can think of is possible the drive shaft is frozen in the crankshaft splines (rust), and the water pump pin has pulled thru the impeller housing BUT the lower portion of the driveshaft may be too large to travel thru the water pump impeller. If this might be the case, remove the water pump retaining screws. Your problem is a first for me.... and I've been around a few years.
