I am considering the possibility of adding a tachometer to my DT25C.
The motor is mounted on a NON-console flat boat.
Here is the question, what is available that would work for my application? I'm sure that someone out there has thought about this and researched what is available!
The tachometer needs to be large enough to be seen and it needs to be mounted into a housing where it can be mounted to a flat surface. It can not be a flush mount as there is no console to mount it into. I only have a small box mounted that contains my electrical fuses/switches, 12v accessory plug and my fish finder.
Before someone suggests a Tiny Tach, please don't bother. It just doesn't fit the application. The lead is way too short to mount where it can be seen, it is really too hard to glance at and see, and the cost vs. battery longevity is unsatisfactory.
I know that there are tachs available galore for the application, but nobody really addresses mounting them into a pod or housing. All literature addresses flush mounting into a flat surface only and don't give depth dimensions.
So, for the sake of curiosity, what is out there?
Edit/Delete Message
Edit/Delete Message
