Re: 1990 Johnson 15 hp
Check gas tank venting, and all fuel lines; they get hard with age and will suck air where they are clamped onto the barb fittings. Also, be sure the o rings on the two discconect fittings are good(replace them is an easy and cheap way to do this). The plastic top of the carb warps too, check it.
