I have 2003 Bayliner with Mercruiser 5.0, Gen II outdrive. And I am replacing all bellows & impeller since I bought new. I know I have been extremely lucky so far. I had no clue on maintenance. Here are my questions:
1) I found a couple ounces of water inside of U-Joint bellow, but no rust on U-Joint assembly & gimbal bearing is in good condition - Is the normal or should I concern?
2) More than couple ounces of drive oil was dropped when upper unit was separated from lower ? Is this normal or should I change the oil seals?
3) New face seal (oem) bottom diameter is larger than old one. And it is keep sliding up after installed (pressed down) with setting tool ? Is this normal? Then I don?t see any purpose of the setting tool.
4) It seems that the sharp teeth on grounding clips are unnecessarily too high. And they are causing the hose clamp slipping out from the original position during tightening. What is the purpose of the grounding clip with sharp teeth on the rubber bellows? Mechanical locking, grounding, or both?
5) It seems that the shift bellow opening is too close to the exhaust bellow opening. There is no clearance for the shift bellow (even without glue) after the exhaust bellow installed. Should I stretch the exhaust bellow to reduce the diameter with hinge pins installed or any other tricks?
I am thanking you in advance for your help.
