First off - what a fantastic website / forum for collected wisdom on all outboards. I have just acquired a 1950/1 Johnson Seahorse 5HP TN26 (SN 102941). It is in great shape (I think) and destined to go on a seaflea that I am building. It doesnt run yet, but was well put away.
Bottom end been drained and refilled with correct oil.
1. Water pump : where is it and how can I get it out to look at it / get a new impeller?
2. Compression : I have measured this on both cylinders to be about 40 psi which seems low. Should I even be bothering with a rebuild? This was done with a slow wrench on the flywheel bolt.
3. Rebuilt the carb, but it still has the old cork float in it and leaks a lot now. Advice on where to get carb rebuild kit from please and what parts are likely to need replacing.
4. Fuel tank : drained, cleaned and pressure checked. All good, even the supply tap.
5. Electrics : in great shape really.
Has the central round magnet although this is not very strong - should it be? If so, can I re-magnetize it?
Coils look great as do the points including bakelite actuators - will clean & gap accordingly (20 thou right?).
Hard to tell if the condensers are OK ; is there a simple way to do this with a multimeter?
Plug wires are a little shoddy - again, where to be sourced.
Plugs looked OK, but should be replaced as a matter of course right? (30 thou gap?)
Sorry to lump all these questions together, but I am sure that all this and more is in this forum. Looking forward to making some real progress on this one soon as the flea is almost complete!
cheers & thanks in advance.
