U Joint Bellows
bikemtn
So I neglected to fully read the instructions on installation of u joint bellows. 1988 Alpha One. I glued and installed the transom side first. Can the bell housing side go on easily? Do I need to pull of and install bell housing side first? And if so is that even possible to do given it is glued and clamped?
Re: U Joint Bellows
Ayuh,.... I've never tried it that way, so I can't say if it's possible,....
Try it, 'n come on back, 'n tell Us 'bout how it went,.... :D
I'd undo it, clean up the old glue with a scrubby pad, 'n try again...
