1996 Johnson Fast Strike Problems 175HP
whitetailbuck1
My problem started last summer in July, when attempting to put the boat on plane, the engine power would slowly gain RPM's then catch and whiplash me up on plane. It might do it once a day or several or not at all. Then on my last trip last fall, could never get full power to put it up on plane. Engine starts and idles fine, Replaced the VRO pump as this had fixed a very similar problem in 2002. Not very mechanical, so looking for a starting point on what to check. Thanks!
boobie
Re: 1996 Johnson Fast Strike Problems 175HP
First check your compression. Then get an open air gap spark tester ( available at any parts house ), set it to a 7/16 " air gap and see what you get. A good place to start.
SparkieBoat
yep..the boob has spoken...listen to him and success you will see. yoda
