Im cleaning up a 1979 Glastron Sea Fury cuddy, it had a 94 Johnson Ocean Runner on it that I sold and picked up a Honda 4 stoke... The notched transom is bowed out in the middle by 1/4 - 3/8 inch, the transom tested well and isnt rotton, is there something I can do to reinforce the transom (steel plate, transom knees, or even a lower mounted bracket for the new outboard) or do I need to worry about a major repair before I mount anything on the transom? the transom was solid when the Johnson was on, no flex in the transom. Thanks, Rick.
