Re: Need engine temp sender and gauge for 1977 Chrysler 135
The overheat indicator is either a buzzer or a 12 volt dash light--available at Radio Shack.
The sender is a misnomer: It is actually a switch that is normally open. When overheated, a bi-metal strip closes the switch and voltage goes to ground. The switch is a 1/4 - 20 screw with a 5/8 head and the bimetal glued to it. It can usually be either red or black. It screws into the head right next to the #2 sparkplug. If you need this switch, you can probably get it at
franzmarine@aol.com.
Newer Force engines have the switch inside a well on the head and held by a rubber plug. You can NOT use this switch as there is no place on your engine to put it (unless you modify it by making a clamp to hold it to the head.)
NOW: If you want an actual temperature read-out, you can buy a sender and gauge. One type screws into the top of the head where the stainless slotted plug is. It is 1/8 NPT threaded. A second type is simply held tight against the head with a bracket and screw--simpler but not quite as responsive. Both these types come as a set --- sender and gauge.
The indicator buzzer is wired with one lead to the "I" or "A" terminal of the switch. the other lead attaches to the orange wire. While the ignition switch is in the run position, power is supplied to the buzzer or light. When the switch on the head grounds, power flows and the buzzer will sound or the light will glow.
