Re: Help with Gamefisher 9.9
Hi RW....
Lets face it; the reason people haven't answered you is simple. They don't know the answer to your question at the moment. Some of them are probably going to look through their reference material when they get the time.
I wouldn't take it personally....
Your motor was manufactured by Chrysler/Force/Mariner. You might try posting on the Chrysler/Force board here...or simply googling your motor's model number. That's what I just did.
Does your flywheel have three bolt holes in it in a circle around the center nut? Most flywheels do and they are removed with a 3-bolt puller....like this one:
http://www.harborfreight.com/automotive-motorcycle/pullers/46-piece-bolt-puller-set-37824.html
What you DON'T want to do is hammer on the flywheel or use one of the pullers that grabs under it's edges.
I don't know the torque at the moment but it's probably around 40 ft lbs. Someone will either agree or disagree here soon....
Good luck; those Force/Gamefishers are about the only decent motor sold by Sears in recent history. Most are Eskas/Tecumsehs/Clintons.... Be happy. You've got the good one
Chuck
Here's a link that shows your flywheel...and; sure enough...it has the three holes....
http://www.**********/parts/search/...97 1-2)/225.581998/IGNITION SYSTEM/parts.html
boatsdotnet
