3.0 rear mortor mounts
3ddye
? fuel filter got all plugged up and & the ENG started running bad and developed a bad vibration. can the plugtged up filters cause vibration?
THANK YOU FOR YOUR TIME
Re: 3.0 rear mortor mounts
Ayuh,... Welcome Aboard,... The motor mount bolts should be the same on both sides....
If the filter passed any junk, I'd sooner think the carb needs rebuildin'...
