Just below the water line there is a 5 inch by 3 inch plate/cover on each side which attaches by a single screw at the back and a lip at the front. They are not watertight and do not seem to cover any moving parts. Due to corrosion one plate will not lock on the front and although the screw at the back holds it on, it flops around. I am thinking the only purpose is decorative and I can continue to use the motor with plate removed. Hoping someone can advise me.
thanks
thanks
