Re: Starter Amps required for a 1998 115 hp Evinrude
350 might be the cranking amps spec'd for the battery but its not going to take anywhere near that to actually start the motor.
Your question was "What are the needed amps for starting this motor?" I have a DC ammeter I can check mine with when I get home. It wont tell you everything as a COLD motor is going to be harder to turn but it will get you ballpark.
